LOOK OVER THE DESCRIPTIONS OF THE FOLLOWING TWO HOUSES AND
SEE IF YOU CAN TELL WHICH BELONGS TO AN ENVIRONMENTALIST.
HOUSE # 1:
A 20-room mansion (not including 8 bathrooms) heated by natural gas.
Add on a pool (and a pool house) and a separate guest house all heated
by gas. In ONE MONTH ALONE this mansion consumes more energy than the
average American household in an ENTIRE YEAR. The average bill for
electricity and natural gas runs over $2,400.00 per month. In natural
gas alone (which last time we checked was a fossil fuel), this property
consumes more than 20 times the national average for an American home.
This house is not in a northern or Midwestern "snow belt," either. It's
in the South.
HOUSE # 2:
Designed by an architecture professor at a leading national university,
this house incorporates every "green" feature current home construction
can provide. The house contains only 4,000 square feet (4 bedrooms) and
is nestled on arid high prairie in the American southwest. A central
closet in the house holds geothermal heat pumps drawing ground water
through pipes sunk 300 feet into the ground. The water (usually 67
degrees F.) heats the house in winter and cools it in summer. The
system uses no fossil fuels such as oil or natural gas, and it consumes
25% of the electricity required for a conventional heating/cooling
system. Rainwater from the roof is collected and funneled into a 25,000
gallon underground cistern. Wastewater from showers, sinks and toilets
goes into underground purifying tanks and then into the cistern. The
collected water then irrigates the land surrounding the house. Flowers
and shrubs native to the are! a blend the property into the surrounding
rural landscape.
HOUSE # 1 (20 room energy guzzling mansion) is outside of
Nashville,Tennessee. It is the abode of that renowned environmentalist
(and filmmaker) Al Gore.
HOUSE # 2 (model eco-friendly house) is on a ranch near Crawford,
Texas. Also known as "the Texas White House," it is the private
residence of the President of the United States, George W. Bush.
(nuts)
http://www.truthorfiction.com/rumors...ush-houses.htm
or
http://www.snopes.com/politics/bush/house.asp
or
http://www.google.com/search?hl=en&q...eothermal+gore
