Hello, I am having some trouble with controlling my spindle speed through mach 3. I am using a Huanyang 1.5kw vfd connected through a leadshine Mx4660 and controlled by mach3. For the past few months I have been able to control the spindles speeds with mach without any problems, but sometime last week when I was running an operation the speed just didn't increase as it was supposed to. Some background, I start my spindle on the vfd, I click run and it runs up to 7200 rpm then mach takes over from there. I have a backup copy of my mach profile and I loaded up that into mach, it has the same setup for that spindle, and the spindle worked just as it was supposed to. I closed the backup profile and opened it later and now that one wont run the spindle speed.I made a third profile, input the same spindle settings, disabled everything else, and it ran for a while then stopped when I saved and reopened the file. I tried the default Mach3 milling profile, input my spindle settings, and that one currently runs correctly. But all of these profiles have the same setup, but it appears like mach3 is the source of the issue and I can't find much else as to what the issue could be. I checked my main profile to see if anything was using the same pins as the spindle but there are no other inputs or outputs on the spindles pins. If anyone has any suggestions I would appreciate the input. Let me know if you needs any more information.
Thank you, Austin
