585,991 active members*
6,512 visitors online*
Results 1 to 6 of 6
    Mar 2018
    3
    Spindle Speed Control Stopped Working
    Hello, I am having some trouble with controlling my spindle speed through mach 3. I am using a Huanyang 1.5kw vfd connected through a leadshine Mx4660 and controlled by mach3. For the past few months I have been able to control the spindles speeds with mach without any problems, but sometime last week when I was running an operation the speed just didn't increase as it was supposed to. Some background, I start my spindle on the vfd, I click run and it runs up to 7200 rpm then mach takes over from there. I have a backup copy of my mach profile and I loaded up that into mach, it has the same setup for that spindle, and the spindle worked just as it was supposed to. I closed the backup profile and opened it later and now that one wont run the spindle speed.I made a third profile, input the same spindle settings, disabled everything else, and it ran for a while then stopped when I saved and reopened the file. I tried the default Mach3 milling profile, input my spindle settings, and that one currently runs correctly. But all of these profiles have the same setup, but it appears like mach3 is the source of the issue and I can't find much else as to what the issue could be. I checked my main profile to see if anything was using the same pins as the spindle but there are no other inputs or outputs on the spindles pins. If anyone has any suggestions I would appreciate the input. Let me know if you needs any more information.
    Thank you, Austin
    35538
    Re: Spindle Speed Control Stopped Working
    Mach3 .xml files are know to become corrupted on occasion, which is what sounds like is happening. But I've never heard of it happening repeatedly like you are seeing.
    Do you have a valid license in your name?
    I'd create a completely new profile, and when everything is working, save a copy of the .xml file.
    When you have problems, just replace the .xml.
    Re-installing Mach3 may help as well.
    Dec 2003
    24221
    Have you considered the Mach plug in by Royaumedeole using the RS485 link for all control and disply?
    Mach3 plugin for Huanyang VFD | Le royaume d'éole
    Al.
    Albert E.
    Mar 2018
    3
    I have actually never seen this before, but it's is pretty interesting. So am I correct that all I would need is the adapter and the plugins/downloads. Then I can do all my spindle controls in mach3 but through this plugin? I just want to make sure because in the prerequistes section it states a "huanyang with RS485" then a "Rs485 adapter" I am a little unsure if that is talking about two different things. Thanks for the comment, great suggestion.
    Mar 2018
    3
    my license should be fine i think. Creating a new profile and going from there was what I was thinking too, but I tried and it wont run my spindle at all, I might be a little dead in the water with profiles. So it looks like i might have to do a reinstall and see if that helps. otherwise I might try out the RS485 plugin. Thanks for the response!
    Dec 2003
    24221
    I use a cheap (ebay) COM port to RS485 adapter, if you don't have a PC COM port, a USB adapter should work, I would think you need to set the port to simulate a COM port out. I believe others here have.
    But all the commands and reads are sent/received over the link.
    Al.
    Albert E.
  1. Replies: 1
    Last Post: 04-06-2018, 09:27 PM
  2. Syil 2010 model X7 spindle stopped working
    By pdh8953 in forum Syil Products
    Last Post: 11-21-2012, 01:28 AM
  3. Variable Speed Control Not Working - Wiring Diagrams Attached
    By jmccracken in forum Bridgeport / Hardinge Mills
    Last Post: 12-14-2011, 02:17 AM
  4. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
  5. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
