584,871 active members*
5,262 visitors online*
    Mar 2018
    22
    Plasma tourch arc issue
    Hi Guys,
    I'm running a mach3 plasma setup. I have the mach3 USB motion board. If my pierce and cut hight is higher than 1mm the tourch makes a small spark but does not fire. And then 95% of the time it disconnects all USB devices from my pc. The pc issue only happens when the tourch does not fire.
    Nov 2012
    591
    Re: Plasma tourch arc issue
    You'll do better on some Mach-specific forum is my guess. This forum is for the Tormach mills, which used to come with Mach 3 a few years ago.
    Regarding the "PC peripherals stop," that sounds like EMI from an inductive kick-back, which seems likely caused by your arc equipment. You'll need to do all the things to insulate against EMI. Putting the PC on a phase of its own would be a good start, as would EMI protection filters on both PC and plasma circuits, and possibly ferrite rings around all cables going into the control box. (Beware that ferrite on USB may make degrade signal quality, so you may need to not put them on USB cables.)
  1. MAX200 hand tourch not working
    By mzerighi in forum Hypertherm Plasma
    Last Post: 02-09-2017, 05:46 PM
  2. floating tourch?
    By ward2699 in forum Waterjet General Topics
    Last Post: 02-16-2012, 02:38 AM
  3. Almost there. Buying a Dyna Tourch
    By Homer Simpson in forum DynaTorch
    Last Post: 05-04-2009, 07:36 AM
  4. 5 x 10 table for plasma / tourch / router - project
    By ajclay in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 03-21-2008, 12:30 AM
