585,975 active members*
4,399 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > run g-code in inches on Laguna machine set for MM?
Results 1 to 12 of 12
    Feb 2011
    33
    I have a bunch of g-code files that are formatted in Inches. I run them on Mach3.
    I'd like to join a co-op that uses a Laguna machine. It seems to be set up for MM.
    I did a quick test and renamed a .nc file to .mmg. After some fussing with the origin, we did get it to run, but it barely moved the cutter.
    So afterward, it looks like the machine is set for mm.
    Is there a setting to just tell it to run in inches?
    I have a program that I could use to convert my files, but that would take a long time to do them all.
    Any ideas?
    Chris
    15362
    Re: run g-code in inches on Laguna machine set for MM?
    Quote Originally Posted by chris2112 View Post
    Any ideas?
    Chris
    Its very simple all you have to do is add a G20 for inch and G21 for metric, at the start of the program, this tells the control that you want to run a program that is formatted in inches=G20
    Mactec54
    Feb 2011
    33
    Hmmm. I think I have that. So the beginning of my code is:
    N10 G20
    N20 G0 G17 G40 G49 G80 G90
    N30 G64
    N40 (first body - ZERO Xtra deep pocket)
    N70 S10000 M03
    N80 G01 X20.5963 Y11.8868 Z0.25 f50.0
    N90 G01 Z-0.2275
    The beginning of a sample from the shop is:
    (Filename: V-Carve 1)
    N10M03S16000
    N20G00X-23.524Y-54.217Z5.080
    N30G1Z-5.080F508.0
    N40G1X-23.040F1270.0
    N50G1Y23.289
    N60G2X-20.107Y26.222I2.933J0.000
    N70G1X5.525
    I thought that S16000 was the speed, but 1600 would be more like 65 inches, which is in the range. But this is 650 inches. So maybe something else is up?
    S16000 is the RPM.
    Use find and replace to change all the F commands, which are the feedrates. Multiply them by 25.4.
    However, depending onthe type of Laguna, it may not support G20/G21. I think the Laguna Swift may be metric only.
    Feb 2011
    33
    So if the code I tried with the G20 ran in mm, then I'm probably stuck there.
    On my machine, I use a manual switch on the router to set the RPM. So I'll need to add that to each file.
    I'll try that, change by feed rates, and convert to mm and see if it works.
    Bummer some are metric only. What a pain. I think I have 1,000s of files. I use 25 or so most of the time though.
    S16000 is the RPM.
    15362
    N10 G20
    N30 G64
    N70 S10000 M03
    N90 G01 Z-0.2275
    N10M03S16000
    N30G1Z-5.080F508.0
    N50G1Y23.289
    N70G1X5.525
    Look up the spec's for the control to see which codes the control excepts most will do both
    If you Program is Witten like above the F would not be recognized, it can not be lower case you have ( f ) for feed, it has to be ( F ) your Feed rate is F50. which is 50IPM
    The M3S1600 is your spindle speed
    Is the V carve-1 program in inches or for metric, if it is for inches then your feed rate would be way to fast at F508.
    Mactec54
    Feb 2011
    33
    The top code works fine in Mach3. That is what I have been using. The bottom is a Laquana compatible example. Good point though if a generic controller like caps.
    I see the spindle speed command now. I'll need to add those.
    I read the older controllers use G70 for inches. I'll try that.
    The info on the controller I was able to get is that it is a "Laguna IQ HHC". I'm not sure on anything Laguana. I know Mach3 well though, at least for what I do.
    15362
    No G70 would not be used for anything in your control, I believe that they are Metric only, but without a G Code list that your control uses, it hard to say if it will do both with just a code change, someone I know has one and he will know what it can do
    Mactec54
    Feb 2011
    33
    So I did find out that this machine only runs metric, in mm. I have en editor that I used to convert my code. I can do a "scale" on all 3 axis by 25.4 That seemed to work on the first program. The beginning is posted above. I tested that code, then converted the rest.
    So I went back today, and only the first program works. The rest say "out of range" or something like that. I have 8 I need to run to make a guitar.
    I checked them in Mach 3 and noticed the next programs still had the G21. I figured the laguana would run metric no matter what but maybe this needs to change to g20 like the first one?
    I'm not totally familiar with the Laguana. I'm pretty sure we did a ref-home, then set what mach calls an "offset" to get it in range. Then the next programs should have been aligned with each other.
    It is an hour commute to this place, so I'd like to have more than one thing to try.
    Any ideas?
    Jun 2010
    81
    I run an inch post on my Laguna IQ and it works fine. All you need to do is change the post to call Feed rates in metric..
    N2 (Filename: .236 Rough)
    N3 (Saturday August 04 2018 08:01 AM)
    N4 (Machine: Laguna IQ HHC)
    N5 (Material Size)
    N6 (X= 24.000, Y= 12.000, Z= 0.260)
    N7 (.236 End Mill)
    N8 G90
    N9 G20
    N10 G00 Z2.000
    N11 M03 S18000
    N12 G00 X3.459 Y4.438
    N13 Z0.100
    N14 G01 Z-0.060 F1270.0
    N15 X3.387 Y4.455 F1524.0
    N16 X3.364 Y4.417
    N17 X3.459 Y4.438
    N18 X3.478 Y4.530
    N19 X3.413 Y4.545
    N20 X3.342 Y4.565
    N21 X3.174 Y4.277
    N22 X4.133 Y4.494
    N23 X4.082 Y4.489
    I was helping a Laguna user recently, and found out that it would run G0 and G1 moves in inches, but not G2/G3 moves. It seems to autodetect inch units and work properly, but not with arcs.
    Feb 2011
    33
    I tried the g20. I didn't work. The laguana support said it was metric only, but he didn't seem very sharp. I'll try your entire header, but I doubt it. The conversion works, but is a pain. Chris
    Quote Originally Posted by cbr_speedster View Post
    N5 (Material Size)
    N7 (.236 End Mill)
    N8 G90
    N9 G20
    N10 G00 Z2.000
    N11 M03 S18000
    N13 Z0.100
    N16 X3.364 Y4.417
    N17 X3.459 Y4.438
    N18 X3.478 Y4.530
    N19 X3.413 Y4.545
    N20 X3.342 Y4.565
    N21 X3.174 Y4.277
    N22 X4.133 Y4.494
    N23 X4.082 Y4.489
  1. Replies: 3
    Last Post: 11-27-2016, 04:43 AM
  2. Replies: 2
    Last Post: 04-02-2016, 08:46 AM
  3. Machine cutting thing far too big or too small. (Laguna Swift 4x4)
    By Dippeggs in forum Commercial CNC Wood Routers
    Last Post: 08-10-2015, 04:39 AM
  4. Replies: 3
    Last Post: 04-10-2015, 04:42 PM
  5. laser cutting machine 51*35 inches in Canada
    By lasertube in forum Commercial Laser
    Last Post: 02-25-2015, 06:08 PM
