585,685 active members*
4,444 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Mach 3 PWM signal to control mc2100e motor controller
Results 1 to 3 of 3
    Jan 2018
    Pretty new to all of this, last winter I set to and converted an Emco compact 8 lathe to cnc control of the x and z axis. The mechanical side of things I understand well enough, the electronics not so much, so I used a 2-axis kit from CNC4you.co.uk. The breakout board I'm using is this one - https://cnc4you.co.uk/resources/KK01.pdf
    To my surprise the whole thing works well, and is proving a useful machine.
    For 'phase 2' I'd like to add variable spindle speed. A cheap eBay purchase and an hour with some spanners and I've liberated from a treadmill a suitable DC motor (2hp) and the mc2100e control board. My first thought was to control the spindle speed manually with a knob, but this turns out to be slightly trickier with this particular motor controller - it requires a 5V PWM signal to control the speed of the motor.
    Then again - surely I can provide this straight from Mach 3 somehow? Doesn't that sound like a fairly elegant solution?
    I notice the breakout board diagram has '+5V' all over the place on it......
    Can anyone point me in the right direction how to do this?
    Thanks in advance!
    Andy
    Dec 2003
    24220
    Re: Mach 3 PWM signal to control mc2100e motor controller
    The conversion is not that simple, the PWM freg period for the input is only 50ms and also the input requires a series resistor for the opto as there is just a small value under 100ohms for the opto.
    There is alot of info on the web for the nature of the input, I am just experimenting with a Picmicro interface for one right now.
    If I get the time I would like to create a circuit to enable the Mach3 RS485 huanyang plug in to be used.
    Al.
    Albert E.
    Jan 2018
    Hmm thanks Al - it was too much to hope it would happen to be straightforward!
    A project to pursue down the line I think.
    Maybe I'll be content with attempting to control it manually for starters
    A
  1. Manual control of MC-2100 treadmill motor controller?
    By murph64 in forum CNC Machine Related Electronics
    Last Post: 02-10-2024, 10:00 PM
  2. control stepper motor driver controller L297 using Pic ????
    By watzmann in forum CNC Machine Related Electronics
    Last Post: 04-12-2012, 11:09 PM
  3. Replies: 0
    Last Post: 10-25-2011, 07:30 AM
  4. configuring Mach 3 for twin X axis stepper motor control
    By Alex2005 in forum Mach Software (ArtSoft software)
    Last Post: 03-07-2008, 09:15 AM
