Re: Geometry offsets
What you can do is use a manually touched off tool that has the correct offsets to re-calibrate the sensor. Use the G124 cycle with the appropriate parameters to correct the sensor. I've attached a renishaw manual for the Q-setter that should help you to understand the parameters and how to do it.
0500 Calibration program.
G124K2.T2. H3. Calibration of 4 stylus faces using preset OD tool #2.
M30 End program
In this example, tool 2 would be already calibrated. Then the tool would be positioned within .2" of the stylus on both x and z (above and right). Then the cycle would be run to calibrate the probe.
All 4 faces are calibrated in this example. See chapter 4 for details.
I have seen some different g-codes being used, so please confirm on your machine.
Best regards,
Experience is what you get just after you needed it.
