585,729 active members*
5,003 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > Lubricate Diagram for MORI SEIKI SL-2B.
Results 1 to 2 of 2
    May 2017
    Lightbulb Lubricate Diagram for MORI SEIKI SL-2B.
    Hi everyone,
    I've created this article for the purpose of requesting help with the lubricant diagram on my MORI SEIKI SL-2 since there is an issue on the upper slide way Z-Axis lubricant.
    Note that, all the ports were cleaned and replaced with new tube. (see attached photos)
    Thank you.
    Sep 2004
    148
    Re: Lubricate Diagram for MORI SEIKI SL-2B.
    You need to change the metering fittings as well.
  1. Replies: 1
    Last Post: 09-05-2014, 06:48 PM
  2. Mori Seiki AL 2 AT W/ 10TF LADDER DIAGRAM.
    By jdeere4250 in forum Mori Seiki lathes
    Last Post: 03-12-2013, 10:44 PM
  3. Ladder Diagram for Mori Seiki MV40/Fanuc 6M-B
    By Randy K in forum Mori Seiki Mills
    Last Post: 03-06-2012, 11:21 AM
  4. Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 05-05-2011, 04:12 AM
  5. Wiring diagram for Mori Seiki TL5 with Yasnac 2000g control
    By frank12933 in forum DNC Problems and Solutions
    Last Post: 04-21-2008, 07:30 PM
