585,997 active members*
4,844 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Cutting/forming tiny splines on aluminum
    Nov 2017
    591
    These will be for servo arms for an rc helicopter. I can buy them for 8 bucks each or so, but would like some custom ones if I can do it. It's about a 1/4 inch hole with 25 teeth in it. I have some extra servo gear sets at my disposal with the male spline on it. I'm wondering if I can somehow modify one of the male splines to cut or form the female spline in the servo arm. Maybe either a taper on the leading edge to help for forming when pressing in, or cut a counter sink shape into the end of it to make sharp teeth for cutting as i press it in. Either way I would bore the hole and form or cut the spline before milling it to prevent expanding as I press the male spline in, then machine afterwards. There is also a through hole for bolting the arm down so after pressing the male spline in, I can press it back out afterwards. Could either of these approaches work? How would you do it? I'll try to post a pic of one
    Re: Cutting/forming tiny splines on aluminum
  1. Feeds, speeds, doc, woc for tiny endmill in 7075 aluminum
    By QuinnSjoblom in forum MetalWork Discussion
    Last Post: 05-24-2018, 09:37 PM
  2. Obtaining mirror finish on aluminum molds with tiny features
    By bebob1 in forum MetalWork Discussion
    Last Post: 01-29-2012, 07:36 PM
  3. cutting splines??
    By inthedark in forum Uncategorised MetalWorking Machines
    Last Post: 04-29-2009, 04:07 AM
  4. Cutting Internal Splines?
    By Krusty Karl in forum MetalWork Discussion
    Last Post: 11-12-2008, 06:32 PM
  5. Thread Forming Aluminum
    By Tazzer in forum MetalWork Discussion
    Last Post: 03-07-2006, 05:11 AM
