Which brand of fiber laser cutting machine is easy to use? Now the fiber laser cutting machine market is mainly divided into foreign and domestic. Nowadays, the foreign fiber laser cutting machines commonly used in the market mainly include German Trumpf and Swiss Baichao. The well-known domestic ones mainly include Dazu Laser, Huagong Laser and Hongshan Laser. Which brand of fiber laser cutting machine is not the most important, the most important thing is to look at the needs of the enterprise itself, choose the fiber laser cutting machine of the right enterprise.
40W Desktop Laser Engraving Machine
The choice of fiber laser cutting machine depends on what industry it is. Different fiber laser cutting machine manufacturers have different emphasis. Some manufacturers pay attention to small fiber laser cutting machines, and few high-power products. Hongshan laser products Mainly focus on small and medium-sized fiber laser cutting machine, the power of the machine is between 500w-2000w. The choice of fiber laser cutting machine can refer to the following points:
50W Laser Cutting & Engraving Machine
First, the choice of model
The purchase of fiber laser cutting machine needs to be based on the material and thickness of the processed product, as well as the quality of the cutting product and the cutting speed. Firstly, the type of equipment to be purchased is determined. It is a special machine for plate, a special machine for pipe or a machine for tube sheet.
60W Laser Cutting Machine
Second, configuration choice
According to the material of the processed product and the processing requirements, especially the processing thickness and piercing ability, choose the configuration of the laser cutting machine, such as the power of the equipment.
Third, examine the stability of the machine
CNC system is the most important part of a laser cutting machine. It determines the value of the equipment and is one of the key factors in selecting the machine. The hardware of the CNC system determines the stability of the system. The control software determines the cutting quality of the fiber laser cutting machine. And efficiency.
80W CO2 Laser Cutting Machine
Fourth, airport quality and accuracy
After determining the model and configuration, you can observe the quality and accuracy of the fiber laser cutting machine. The airport structure of the fiber laser cutting machine, the quality of the gear, the grounding of the machine tool, and the accuracy verification of the fiber laser cutting machine are all related. The factor of cutting quality to fiber laser cutting machine.
