585,997 active members*
4,844 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Rigid tapping not authorised G84.1
    Sep 2017
    10
    Hello everybody!
    I have Cincinnati Dart 500 from 1999. Last time i tried to tap with cycle G84.1. Unfortunately, the machine showed me an alarm:
    Does this mean that I have to install hardware elements? Or I need to unlock with special code?
    Best regards,
    Adrian
    Aug 2015
    100
    Re: Rigid tapping not authorised G84.1
    I think all you need is to have the special code. I dont think you need to add any hardware. I may be wrong, but my machine I bought used came with Rigid Tap enabled and I dont see any special hardware that would have been installed for this.
    Dec 2006
    584
    The dart is a basic machine/control, you need to contact Mike Trunk at FIVES 800-934-0735 to get a code. You should press MORE then CONFIG then PURCHASED OPTIONS to see what you have.
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Sep 2017
    10
    Hello!
    Thank you very much for the answer, on Tuesday I will be in my workshop, I will check what option I have and then I will contact Mike. I know that I have a service level in the machine, so it should be a bit easier.
    Best regards,
    Adrian
  1. Replies: 1
    Last Post: 07-06-2014, 04:44 AM
  2. Replies: 24
    Last Post: 05-01-2014, 07:02 AM
  3. Replies: 13
    Last Post: 07-04-2009, 12:43 AM
  4. Tapping head or rigid tapping
    By Gregory_C in forum Syil Products
    Last Post: 10-18-2008, 06:49 AM
  5. Rigid tapping or tapping head
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 09-24-2006, 06:08 PM
