585,987 active members*
4,654 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc OM tool changer problem Kiwa (Excel 510)
Results 1 to 6 of 6
    May 2017
    19
    Hello All,
    I have a Kiwa ( Excel 510) VMC (1985) with Fanuc OM controller.
    The machine is new to me, so I am working out its quirks.
    Everything seems to be OK except tool changer.
    I can use the ATC via the manual mode, and change one tool at a time and that seems to work OK.
    But If I call a tool change via a program T01 M6, etc, it does not work.
    It will remove the tool from the spindle, spin the carousal apparently looking for a tool and then eventually time out lighting up the feedhold light.
    If anyone can shed some light on this issue for me that would be great.
    If you need specific info to help me, please let me know.
    Dec 2009
    953
    Re: Fanuc OM tool changer problem Kiwa (Excel 510)
    i think you miss some diagnose inputs
    my email:[email protected]
    or facebook:zavateandu--the picture with my 2 daughters not the plane
    i can help,last week i just restore a KIWA 510 after paramaters lost and that simtomps you described ,i met while recovering and i fix it by diagnose inputs.
    Apr 2009
    108
    This will happen on the 510 if the machine is phased backwards. Be certain that the magazine numbers count up when you are rotating the carousal manually. If not, check the phasing on the machine. I attached a pdf that I wrote many years ago that shows how to adjust the tool changer on the 510.
    May 2017
    19
    I will check both suggestions!
    Dec 2009
    953
    Changing the phases did the trick nice 1 Shoprag,it is umbrella type,i was thinking of double arm
    May 2017
    19
    Yes phases were the issue, thank you for the help!
