585,727 active members*
3,825 visitors online*
    Mar 2018
    22
    Unhappy Mach3 relay blows
    Hi I was using a Cut 60H plasma machine (60A) and all was working fine. I now went to a 100A Jasic plasma cutter and now it keeps blowing my relay that is switching is on and off. Is there a better relay I can use to to the same and works from the int pin from my mach3 BoB?
    Apr 2015
    170
    Re: Mach3 relay blows
    At a guess a 100 amp plasma cutter is going to need at least 30 amps to power it which far too much for a relay to control even more so if it an inductive load. You need to be using a suitably sized contactor which in turn is powered by the relay.
    Mar 2018
    22
    Thanks for the reply, I am new to this. Can you maybe send me a photo and a diagram of this contactor you are talking about . As I have no idea what you are talking about. And the people near me is not very clued up
    Apr 2015
    170
    I don't know what sort of electrical factors you have near you so it is hard to advise you, if you check out rs-online and type into the search box for part number 454-7840 it will give you some kind of idea of what you need. You will have to select the coil voltage to suit what is available. I am assuming the plasma power supply to be three phase
  1. Plasma blows relay..........!!!!WHY
    By japes in forum CNC Machine Related Electronics
    Last Post: 06-12-2018, 10:10 PM
  2. spindle relay commanded by mach3
    By shoke in forum DeskCNC Controller Board
    Last Post: 09-22-2017, 03:02 PM
  3. Mach3 Spindle Control w/ Relay
    By kNucklBustr in forum X3/SX3/G0619/G0463
    Last Post: 02-01-2014, 06:12 PM
  4. '' Relay '' on/off sur Xylotex-Mach3
    By marbeau in forum French
    Last Post: 11-22-2011, 08:46 PM
  5. What m-codes control relay outputs in mach3?
    By jedcam67 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-23-2007, 02:37 PM
