585,589 active members*
3,470 visitors online*
    Jul 2018
    Question Current point same as end point of arc.
    Hello every one,
    I have a 5axismaker machine (5axismaker 5 axis CNC Mill & 3D Printer) which I use with Fusion 360 (and the post processor 5AXISMAKER) and Mach3. I made a simple model (a cube with some inscriptions) and for the tool path, I used "2D pocket". But When I try to load the G-code in Mach3, this message appear: Current point same as end point of arc. Block=X11.235 Y72.294 Z-93.669 R1.425
    I understand what is wrong, but I don’t know how to fix it knowing I shouldn’t have to change the G-code (Fusion 360 is supposed to generate it for me). Is that a problem with Mach3 ? Do I have to modify some line in the G-code ?
    here is the g-code and the problematic line according to Mach3 (between ***):
    X12.45 Y71.459 Z-61.131
    G0 X7.25
    Y73.522 Z-92.352
    G1 X9.45 F720.
    X9.597 Y73.56 Z-92.348
    X9.706 Y73.666 Z-92.34
    X9.75 Y73.811 Z-92.342
    G2 X9.828 Y75.138 Z-93.859 R1.425
    X9.906 Y73.622 Z-95.186 R1.425
    X9.984 Y72.294 Z-93.669 R1.425
    X10.063 Y73.811 Z-92.342 R1.425
    X10.141 Y75.138 Z-93.859 R1.425
    X10.219 Y73.622 Z-95.186 R1.425
    X10.297 Y72.294 Z-93.669 R1.425
    X10.375 Y73.811 Z-92.342 R1.425
    X10.453 Y75.138 Z-93.859 R1.425
    X10.532 Y73.622 Z-95.186 R1.425
    X10.61 Y72.294 Z-93.669 R1.425
    X10.688 Y73.811 Z-92.342 R1.425
    X10.766 Y75.138 Z-93.859 R1.425
    X10.844 Y73.622 Z-95.186 R1.425
    X10.922 Y72.294 Z-93.669 R1.425
    X11.001 Y73.811 Z-92.342 R1.425
    X11.079 Y75.138 Z-93.859 R1.425
    X11.157 Y73.622 Z-95.186 R1.425
    ***X11.313 Y73.811 Z-92.342 R1.425*** (there is no space before and after in my G-code, this is just for visual gain)
    X11.391 Y75.138 Z-93.859 R1.425
    X11.47 Y73.622 Z-95.186 R1.425
    X11.548 Y72.294 Z-93.669 R1.425
    X11.626 Y73.811 Z-92.342 R1.425
    X11.704 Y75.138 Z-93.859 R1.425
    X11.782 Y73.622 Z-95.186 R1.425
    X11.86 Y72.294 Z-93.669 R1.425
    X11.939 Y73.811 Z-92.342 R1.425
    X12.017 Y75.138 Z-93.859 R1.425
    X12.095 Y73.622 Z-95.186 R1.425
    X12.173 Y72.294 Z-93.669 R1.425
    X12.251 Y73.811 Z-92.342 R1.425
    X12.329 Y75.138 Z-93.859 R1.425
    X12.408 Y73.622 Z-95.186 R1.425
    X12.486 Y72.294 Z-93.669 R1.425
    X12.564 Y73.811 Z-92.342 R1.425
    X12.642 Y75.138 Z-93.859 R1.425
    X12.72 Y73.622 Z-95.186 R1.425
    X12.75 Y72.839 Z-94.887 R1.425
    G3 Y71.048 Z-93.984 R5.149
    G1 Y71.015 Z-93.968
    Y70.99 Z-93.941
    If you have any advice for me, I will take it with pleasure,
    And by the way, do you know if there is a limit of line for the G-code that Mach3 can accept ?
    cheers,
    Mar 2015
    409
    Re: Current point same as end point of arc.
    Without a license, 50 lines of code!
    I don't get that error when I run the code.
    I think it's 500 lines in demo mode. Either 250 or 500, I don't remember
    15362
    Quote Originally Posted by schweps View Post
    Hello every one,
    G0 X7.25
    Y73.522 Z-92.352
    G1 X9.45 F720.
    G1 Y71.015 Z-93.968
    Y70.99 Z-93.941
    cheers,
    Check the Absolute Incremental settings in General Configuration
    Mactec54
    Mar 2015
    409
    Below the license information from Mach3
    Without a license, Mach3 will operate in Demo mode. While in Demo mode, the software has the following limitations:
    • Mill & Plasma: 500 line gcode limit (10,000,000 limit after licensing)
    • Turn: 50 line gcode limit (10,000,000 limit after licensing)
    • Kernel Frequency locked at 25kHz (only applicable if using the parallel port driver)
    • Set Next Line function disabled
    • Run From Here function disabled
    • Turn: Threading disabled
    • Plasma: THC functions disabled
  1. Replies: 4
    Last Post: 02-20-2017, 12:19 AM
  2. Replies: 5
    Last Post: 09-25-2013, 05:20 PM
  3. cant cut a circle? "current point same as end point of arc"
    By maccrazy2 in forum DeskCNC Controller Board
    Last Post: 02-14-2012, 07:15 AM
  4. What's the point of current limiting a servo?
    By CrazyIvan in forum Open Source Controller Boards
    Last Post: 09-05-2008, 05:26 AM
