I am using Madcam 5Extra,Version 6.0.2018.702. When creating a simple 2D profile, I select the curve to profile and the cutter outline and “direction of cut” arrow appear as normal. However, the profile curve generated is always on the opposite side from that selected. i.e., if I select an outside profile, MadCAM generates a cut on the inside.This error can be easily corrected by selecting the correct radio button in the pop-up window. So, there is a simple workaround.
Just curious if anyone else has seen this behavior.
Jerry
