Re: Animated Simulation
hy gunda i don't have an mu, but i can tell that some system variables related to part 0 work in reality, but lead to errors when program is test in machine-lock mode ( at least on my osp300 lathe )
in lock mode, only virtual machine is executed, and animation may fail if some codes are used
if i rewrite the program in a different manner, i make it work also in lock-mode, and the virtual model simulates without error; i guess it is 2 years since i have done this, and meanwhile i stopped using animation ...
my point is that you should split your program in several parts, and test them individually, for the animation, and those parts should work
when you join those parts, there may be something behind the oo88 that messes up with the origins that are passed to the virtual model, so you should identify this codes that are affected by the oo88, and try to recode them in a different manner
kindly
