585,667 active members*
3,904 visitors online*
    Jan 2006
    Fanuc O-M g41 g42 problems
    We lost the parameters in our fanuc O-M control.
    We restored all parameters and diagnostics.
    Now the cutter comp doesn't work.
    When g41 is read, control alarms out with p/s 10 unusable g code.
    Is there a parameter turned off for g41 g42
    Dec 2004
    75
    im also working on this problem- this machine (miyano TSV-35 fanuc O-M) shows that g41 and 41 are options so im thinking there must be a way to turn these options on. there is also a p;lace in the book that says these codes are part of "group 7" is there a parameter that chooses which groups of g-codes to use?
    24220
    Check Para 907 BIT #6 x1xxxxxx
    Al.
    Albert E.
    Dec 2004
    75
    bingo! Thank you very much.... now i can tell my boss im the hero ha ha ha ha ha ha beat ya to it sgrove no really- we do appreciate it. now i gota go back and re- re program the cutter comp back into the programs
  1. Fanuc problems need help
    By R.thayer in forum Fanuc
    Last Post: 01-27-2007, 03:39 PM
  2. Fanuc 0i-mb 3D surfacing problems
    By isaseraf in forum Fanuc
    Last Post: 10-07-2006, 03:55 PM
  3. Fanuc 3TC problems
    By roni21702 in forum Fanuc
    Last Post: 03-15-2006, 06:00 AM
  4. Fanuc 3TC problems
    By roni21702 in forum DNC Problems and Solutions
    Last Post: 03-12-2006, 04:43 AM
  5. Fanuc Problems
    By scuba in forum MetalWork Discussion
    Last Post: 03-19-2005, 08:19 PM
