When using metal laser cutting machine, we should pay attention to the fire prevention measures and take good fire prevention measures to ensure the safety of our metal laser cutting machine. Therefore, we should understand the use of metal laser cutting machine. , should pay attention to the fire prevention matters.
Then, when using metal laser cutting machine, what kind of fire prevention matters should be paid attention to?
Hydraulic Swing Beam Shearing Machine
1. When using the metal laser cutting machine, check whether the gas path is completely sealed. If there is a leak, it will cause the burning of these flammable gases;
2, the use of metal laser cutting machine is best to keep away from open flames, otherwise it is easy to fire because of too high temperature;
3. Do not let the spot of the metal laser cutting machine stay in one place to prevent fire.
Hydraulic Guillotine Shearing Machine
Below, when using the metal laser cutting machine, we must pay attention to the above fire prevention matters, in order to ensure the safety of the metal laser cutting machine.
