Hi, I'm recently new to mazak. I've learned the basics of a mazak integrex 70 at work and we recently got the v-550 in. I've had a play with the programing and I'm currently trying to do a basic job which is to face mill a block with a 80mm Dia carbide cutter.
Setting to tool on the integrex is pretty straight forward. however I've managed to write a simple facing program on the v-550 run the tool path successfully but when I try to run the program at first the x, you and z axis all homed out and the z axis soft limit popped up instantly stopping the program. I tried to have another play and now I get an error message reading no axis 0 located. (always covering the emergency stop when trial running)
I've tried looking online but can't find anything so far, can someone point me in the right direction with a basic program (to test) and how to set the tool etc.
Because the machine is new to the shop and we have a simple block facing job. We only have the 1 tool as mentioned above. Once I pick up the machine better, more tools will be bought for it.
Thanks for you time.
