585,557 active members*
3,213 visitors online*
Results 1 to 3 of 3
    Jul 2015
    5
    Mitsubishi FX10K - U700 error
    Hello!
    I have problem with Mitsubishi FX10K from 2001, on pressing ready button U700 error is appearing.
    I have found out that BKO-R8784 give only 240V, 150V only appear for 1s and fade to 0v after power is turned on and off.
    What can cause this problem? Is there any solution?
    Jul 2015
    5
    Re: Mitsubishi FX10K - U700 error
    Problem was power supply controling board, one of resistor solder path near connector to power supply was broken.
    Quote Originally Posted by 4d53 View Post
    I also have an FX 20K wire erosion machine. U700 gives wrong PWR SUP error. Could it be the same problem as yours? Can you help me. Can you send a photo of where this card is? I would really appreciate if you can help.
  1. Mitsubishi fx10k
    By thunt481 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-27-2018, 03:39 PM
  2. Mitsubishi FX10K Pitch error parameter help
    By KMcorv22 in forum EDM Discussion General Topics
    Last Post: 05-06-2014, 12:07 AM
  3. mitsubishi fx10k chiller
    By moldman3 in forum EDM Discussion General Topics
    Last Post: 09-21-2011, 10:39 PM
  4. Mitsubishi FX10k vs. Charmilles 310 wire EDM
    By Alanstr in forum EDM Discussion General Topics
    Last Post: 04-20-2010, 07:51 PM
