585,591 active members*
2,786 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > New Set-up, still not working!
    Dec 2017
    47
    Switched to NEMA 23 steppers and TB6600 drivers, motors still only getting 5V, can't figure out what I'm doing wrong, attaching photos of setup, can anyone tell how I need to
    wire this turkey?https://www.cnczone.com/forums/attac...d=397114&stc=1
    15362
    Re: New Set-up, still not working!
    Quote Originally Posted by bjwx2 View Post
    What power supply do you have for the steppers power input, you need at least 24v supply
    Mactec54
    Dec 2017
    47
    Thanks for your reply, have 30V power supply, have 5V and 30V connected properly, what I don't understand is what wires go to enable, step, and pulse.
    If you share some pictures here to show
    We can help you to check
    https://www.automationtechnologiesinc.com/
  1. Setting drills, ID tools and back working/end working tools
    By jonathan2jones in forum CNC Swiss Screw Machines
    Last Post: 04-22-2017, 01:11 AM
  2. What is the difference between wood working and metal working routers?
    By LaughingJaguar in forum Joes CNC Model 2006
    Last Post: 10-17-2016, 07:29 PM
  3. Switch view between machine working enveloppe and job not working?
    By skillalot in forum Screen Layouts, Post Processors & Misc
    Last Post: 08-10-2015, 03:55 PM
  4. thc working or not?
    By empirecustoms in forum Mach Plasma / Laser
    Last Post: 12-21-2008, 11:15 PM
  5. Eia Iso Not Working
    By honk in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-16-2006, 01:17 PM
