Nowadays, the word bender is a leader in the field of advertising signage producing. The error of manual bending is large and it is difficult to adhere the base plate to the word case, and light leakage may occur in the follow-up.The manual work is slower and the workers' expenses are also high. From the processing efficiency to the processing effect, it can not be compared with artificial bending. The bender can be controlled by software, and the materials that cannot be processed by the traditional craft can be easily processed through automatic feeding, automatic slotting, automatic bending and other processes. Like the iron sheet, the galvanized sheet and the aluminum, CNC bending machine can also process. The bender can also match the folded outline with the bottom plate to avoid the light leakage which occurs subsequently.
Wuhan perfect Laser Co., Ltd. specializes in the production of advertising characters, in order to meet the market development of a variety of aluminum profile bending machine, Wuhan perfect Laser Co., Ltd. develops a variety of aluminum profile bending machines. The new bending machine PEL-600A which has just been pushed out is mainly for processing aluminum equipment. PEL-600A has precise structure and economic application, it is the preferred high-end equipment for all kinds of aluminum-type materials (color aluminum plate, single edge, double edge crimping, etc.).
This letter bending machine can slot on the front and back of the material, it has flexible angle of the pendulum knife, automatic feeding, automatic slotting and automatic arc bending, this equipment is programmed, simple, efficient and humanized.
The speed can be adjusted through computer during the machine’s processing so the work efficiency can be highly improved. We also promise free software updates for its whole life.
This aluminum bending machine is used for ad words industry such as producing exposed characters, a variety of surrounding edge words with different sectional material,boundless words, epoxy resin word, unsaturated resin word, all kinds of small words and etc. with high processing efficiency, high precision, and small error.
Features:
1. Rapid processing: high processing speed, just need one molding;
2.High processing precision: The feeding precision of the edge-folding machine can reach 0.01mm, and the bending accuracy can reach 0.4°;
3. Easy to operate: This edge-folding machine is fully automatic equipment with automatic feeding, automatic slotting and automatic bending;
4.Bounding word bending machine is mainly used for aluminum materials like color aluminum plate, single edge, double edge and curling;
5.Saving energy: The total power is 700 watts, and the actual power is less than 700 watts.
