I have an Amada MPL 3015 loader for our Amada laser that keeps giving me troubles.The loader wont completely cycle if you run it in schedule mode. The unit hangs up at the same spot each time, which is when the hydraulics lift the "H" frame up a few more inches, for the fingers to grab the completed parts off the table. The control for the loader itself will shut off completely and have to be restarted.Everything works fine if you manually command it to do every task individually, but not in schedule mode. We are getting way behind with production now because we are unable to run anything over night.Any help would be greatly appreciated.
