585,761 active members*
4,101 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Cincinnati Arrow: 39-81 "spindle drive is not responding" acramatic 2100
    Dec 2009
    22
    Hello,
    I recently acquired a 98 arrow 1000 with a "spindle drive is not responding" 39-81 alarm. I sent the VFS5 in for a rebuild (Kilroy corp) and installed with the same alarm. I've hooked up motion link plus software and get "ERR 17 FEEDBACK LOSS".
    The lights on the drive are as follows:
    active=off (i have never seen this on)
    sys ok=on
    cpu=on
    fault= on (sometimes on startup it will be off but will not try and align spindle and will eventually fault)
    I have checked a few things but my knowledge is limited.
    ensured 230VAC to the machine
    checked spindle motor for short
    resolver feedback via motion link and set to zero
    Checked for overloaded relays/breakers/fuses
    Any and all help is greatly appreciated
    thank you
    Sep 2010
    1765
    Re: Cincinnati Arrow: 39-81 "spindle drive is not responding" acramatic 2100
    Quote Originally Posted by natin View Post
    Hello,
    sys ok=on
    cpu=on
    thank you
    Did you get the new resolver in yet? Are you running?
    Sent from my SM-G900V using Tapatalk
    Dec 2009
    22
    Mike Kilroy spent time with me on the phone and remotely on motion link diagnosing the issue, we found the resolver to be at fault. A big thank you to Mike for all his help!
    no, I have yet to order a resolver.
    Jul 2015
    7
    Hi Mike,
    I have the same machine and the same alarm: 39-81 "spindle drive is not responding".
    A few weeks ago, I had to change the bearings of the spindle motor (1-604-0001). They were severely damaged. I already replaced them.
    Then, as Natin did, I've hooked up motion link plus software and get "ERR 17 FEEDBACK LOSS" and I've hooked up motion link plus software and get "ERR 83 BAD OR OUT OF RANGE".
    Again, as Natin did, I have checked a few things but my knowledge is limited.
    resolver feedback via motion link and set to zero (I am not able to set the zero)
    and the needle on MotionLink, tab "Resolver Feedback", runs smoothly.
    Should I also have to change the resolver? If so, can you provide me with SIemens part number or even a quote?
    Again, as Natan said, any and all help is greatly appreciated!
    Thank you
  1. Replies: 1
    Last Post: 03-27-2018, 11:44 AM
  2. cincinnati arrow 1000 acramatic 2100 batteries
    By dbills in forum Cincinnati CNC
    Last Post: 10-24-2017, 08:32 PM
  3. Post for Cincinnati Arrow 750 , controller Siemens Acramatic 2100
    By bacio70 in forum Uncategorised CAM Discussion
    Last Post: 08-23-2017, 09:14 AM
  4. Cincinnati Arrow 750 with Acramatic 2100...
    By Trigg in forum Cincinnati CNC
    Last Post: 04-29-2015, 10:18 PM
  5. Cincinnati Arrow 2000 Siemens Acramatic 2100
    By skeetskurt in forum Cincinnati CNC
    Last Post: 02-24-2013, 04:07 AM
