Hello all,
I'm using CamBam Plus 0.9.8. so I save my drawings to a CamBam file ( .cb ) and a Gcode file ( .nc ). I use LinuxCNC to run the machine.
By mistake, I erased some link to a .cb file. I mean the file is still there, but it's not complete, so basically I'm unable to open the drawing in Cam Bam. Could there be a way/program I could use to convert the .nc file to .dxf or some other ''image'' file, as long as I can reopen it again with CamBam. It doesn't matter if on the way I was to lose the scale, machining paths or else, I just want to get the drawing back.
I have not succeded to open .nc files with CamBam, Inkscape, or LibreCAD
I also have access to FreeCAD, ArtCam, Solid Work, and Mastercam X5 with little to no experience with these programs. So far I've searched the web and no sign of a solution.
Thank you for your time! and your indulgence since I'm only amateur at CNCing
