Laser cutting technology is widely used in the processing of metal and non-metal materials, which can greatly reduce processing time, reduce processing costs and improve workpiece quality. The modern laser has become the "sword" of the "cutting iron and mud" that people are imagining. Taking our CO2 laser cutting machine as an example, the whole system consists of control system, motion system, optical system, water cooling system, smoke exhausting and blowing protection system. It adopts the most advanced numerical control mode to realize multi-axis linkage and laser speed-free. The influence of equal energy cutting, at the same time support DXP, PLT, CNC and other graphic formats and enhance the interface graphics processing capabilities; the use of superior performance of the servo motor and transmission steering structure to achieve good motion accuracy at high speed.
1500W Dual Drive Metal Tube Laser Cutting Machine
Laser cutting is achieved by applying high power density energy generated by laser focusing. Under the control of the computer, the laser is discharged by pulse, thereby outputting a controlled repeated high-frequency pulsed laser to form a beam of a certain frequency and a certain pulse width, and the pulsed laser beam is transmitted and reflected through the optical path and focused by the focusing lens group. On the surface of the processed object, a subtle, high-energy-density spot is formed, and the focal spot is located near the surface to be processed to melt or vaporize the material to be processed at an instant high temperature. Each high-energy laser pulse instantly sputters a small hole in the surface of the object. Under computer control, the laser processing head and the material to be processed are continuously moved relative to each other according to the pre-drawn pattern,
1000W Dual Drive Sheet Metal Laser Cutting Machine
so that the object is processed into The shape you want. When cutting, a coaxial airflow with the beam is ejected by the cutting head, and the molten or vaporized material is blown out from the bottom of the slit (Note: if the blown gas and the material being cut produce a thermal reaction, the reaction will provide cutting The additional energy required; the airflow also cools the cut surface, reduces the heat affected zone and ensures that the focusing mirror is not contaminated). Compared with traditional sheet metal processing methods, laser cutting has high cutting quality (narrow slit width, small heat affected zone, smooth cut), high cutting speed, high flexibility (any shape can be cut freely), and a wide range of materials. Adaptability and other advantages.
