Stainless steel is used in a wide range of households, such as kitchen gas stoves, microwave ovens, gas stoves electronic components, cabinets countertops, kitchen hardware and so on. Using laser cutting equipment, stainless steel can be cut plate, pipe cutting, drilling and other processing.
Stainless steel cookware, cutlery, high temperature, easy to clean, good overall value.Stainless steel pendants, hardware, high hardness, high precision, wear resistance, easy to clean. Stainless steel counter tops are integrated, there is no health corner, wear-resistant dirt, and now the whole stainless steel cabinet, has also become a choice for many families!
There are gas stoves, gas stoves, ovens, microwave ovens, etc., which use many stainless steel electronic components, high accuracy, corrosion resistance, help these kitchen equipment to better function, and have a longer life.
This shows that stainless steel is widely used, and various types of stainless steel processing are particularly important. Common stainless steel cutting methods include high pressure water jet water jet water cutting, step punching, file cutter, disc shear, grinding wheel cutting, and laser cutting. Among them, the stainless steel sheet laser cutting machine occupies a large proportion in industrial production.
Laser cutting uses the energy released when the laser beam hits the surface of the steel plate to melt and evaporate the stainless steel. Generally, a CO2 laser cutting machine or a fiber laser cutting machine is used, and the power is 500 to 2500 watts. This level of power is lower than many household electric heaters require.
However, with the lens and the mirror, the laser beam is concentrated in a very small area. The high concentration of energy enables rapid local heating to evaporate the stainless steel. Since the energy is very concentrated, only a small amount of heat is transferred to other parts of the steel, resulting in little or no deformation.
Using a laser, very complex blanks can be cut, and the cut stock no longer has to be further processed.
The use of laser cutting equipment can cut stainless steel below 4mm. Adding oxygen to the laser beam can cut stainless steel 8 to 10mm thick, but after oxygen cutting, it will form a thin oxide film on the cutting surface. The maximum thickness of the cut can be increased to 16mm, but the size of the cutting part is larger.
Fiber laser cutting machine processing sheet metal
Laser cutting equipment is expensive, but it reduces the cost of subsequent processing. At the same time, the use of laser cutting machines has no tooling costs.
Therefore, whether it is a large-scale production, or a small-scale production, laser cutting machine is a good choice, for some of the original size can not be processed, special parts, laser cutting machine has a significant advantage.
Currently, laser cutting equipment generally employs a computerized digital control technology (CNC) device. With this device, cutting data can be accepted from a computer aided design (CAD) workstation using a telephone line.
