Hello everybody!
A specific problem occurs whenever I try to plasma cut with 80 A electrode. The machine (Messer MetalMaster) works perfectly with other electrodes, so I think the CAM software has a bug or it might be set up badly. The problem is that while cutting interior contours (holes for ex.) the movement is stopped for a brief second and then continues. This causes quality issues on the cutting surface.
The software is called OmniWin 2011. The function I use to create the plans for the machine is OmniNest. In the simulations it doesn't throw up any problems, so I am clueless. Has anyone had a similar problem? The software is old, and only works on Windows XP, so the fact that its full of bugs is not excluded.
Thank you in advance, for the help!
