585,687 active members*
4,534 visitors online*
Results 1 to 1 of 1
    Fiber Laser Engraver, Fiber Marking Machine
    https://www.automationtechnologiesin...rking-machine/
    Now we have 20W, 30W,50W in stock.
    If you need a Rotary Device, add $500
    This type laser marker suitable for Gold, Silver, Diamond, Sanitary Equipment, Foods Packing, Tobacco Label, Beer label, Drink Label, Medicine Packing, Medical Equipment, Glasses and Clock, Auto Parts,Plastic&Paper Materials, The Electron,Hardware which with high request for depth,smooth, accuracy such as horologe, Mould, bitmap marking etc.
    Check machine testing video here:
    https://www.youtube.com/watch?v=ZtsR02uyROE
    https://youtu.be/TzBYwCZB5V8
    https://youtu.be/a-U1oIglpfE
    The machine come with a user-friendly software. It is compatible to CorelDraw, AutoCad, and Photoshop if you need handle more complicated art work. It's an excellent candidate for bar code printing and stainless steel engraving.
    (1):
    Raycus fiber laser module, life time is more than 100,000 hours for 30W and 50W fiber laser Machine
    Maxphotonics fiber laser module, life time is more than 100,000 hours for 10W, 20W fiber laser Machine
    (2): Scanning mirrors;
    (3): NORTH-SMITH field lens from America;
    (4): Control system: J?Z, software: EzCad, WinXP, Win7, Win8 , Win10 , 32 /64 bits
    Systems are supported;
    (5): Easy-focusing device;
    (6): Air Cooling;
    (7): Protective cover (Optional)
    Packing information of fiber laser marking machine :
    Machine Size: 60x 22x52cm
    Package Size: 91x83x163 cm
    Net Weight: 30kg around
    Gross Weight: 50kgs
    Main specification:
    Laser Source Fiber Laser
    Output Power 10, or 20, 30W, 50W
    Wavelength 1060nm
    Beam Quality < 2
    Repeat Frequency 10khz--- 100khz
    Pulse Energy 2 mJ
    Beam Divergence -0.3 to +0.3mrad
    Laser Class IV
    Resolution 18?
    Repeatability 50?
    Marking Scope 110mmx 110mm/ 175mmx 175mm (optional)
    Linear Speed 800 character/ s
    Marking Linear Speed ?12,000mm/s
    Marking Depth 0.01 to 0.5mm according material
    Min. Line Width 0.012mm
    Min. Character Size 0.15mm
    Repeat Accuracy ±0.003mm
    Input Power 0.5kw
    Electrical Source 110V 50/60Hz /4A
    Attached Thumbnails Attached Thumbnails 20WLASER.jpg   0.jpg   webwxgetmsgimg.jpg   webwxgetmsgimg (1).jpg
  1. Replies: 0
    Last Post: 05-18-2017, 08:03 AM
  2. Replies: 0
    Last Post: 03-28-2016, 05:39 AM
  3. AK10F- A Portable Fiber Laser Marking Machine for Plastic, Fiber and Metal Engineerin
    By aaronhernandez in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-29-2016, 05:35 PM
  4. Replies: 0
    Last Post: 06-14-2013, 08:53 AM
