585,977 active members*
4,670 visitors online*
Results 1 to 1 of 1
    3040 CNC Router, 5 Axis Engraver Engraving Machine
    https://www.automationtechnologiesin...outer/hy-3040/
    Brand New 3040 CNC Router, 5 Axis Engraver Engraving Machine, Precision Ball Screw and 1500W Spindle
    USA Tech Support (847-984-0882)
    Check Testing video here:
    https://youtu.be/Z7RxJBCs8qM
    https://youtu.be/2GsaHf7X7ak
    You can update to USB or Ethernet Board:
    Mach3 USB
    Mach4 USB
    Mach3 or Mach4 ESS board
    1:Product Dimensions: about H 20.5 " x L 26" x W 22.8"
    2:Effective Working Area : about 11.8" x 15.7" x 5.9" ( 300 x 400 x 150mm)
    3:1605 Precision Ball Screw
    4: XY Rail diameter: 20mm hard chrome shaft, Z-axis Rail 16mm hard chrome shaft.
    5: XYZ stepper Motor: NEMA23 250 OZ / IN (2.2N/CM)
    6: Repeat Positioning Accuracy: 0.005 inch , Precision: 0.007 inch
    7: Max. Speed: 0-157 inch/minute
    8: Maximum table load: 50KG
    9: Stainless Steel tailgate
    10: 24V/ 14.5A 350W Switching Power Supply 110VAC
    11: 1500W Water-cooled Spindle, ER11 collet
    12: 1500W VFD
    13: 5 Axis control with Mach3 parallel port
    14: NEMA 23 stepper, the transmission ratio 1:6
    Electrical properties: (ambient temperature Tj = 25 ?):
    Input Power: 110V AC power supply
    Stepper: 200pulses / 1.8 degrees, the entire 40-step driving pulse / 1MM
    Drive mode: two-phase 3.5A drive.
    Weight: about 40KG.
    Mach3 software to run the machine
    one year parts warranty
    Attached Thumbnails Attached Thumbnails 3040A.jpg   3040B-150x150.jpg   3040C-150x150.jpg   3040E-150x150.jpg
