585,597 active members*
3,218 visitors online*
    Apr 2018
    3D laser tube cutting problem
    Hello All,
    I have a problem with some laser-cut tube that I sent out.
    The part is 6” diameter 316L tube, 8” long with about a dozen 3/4 and 1 3/8” diameter holes.
    I got a test piece back from my regular service and the inside of the tube is severely contaminated with spatter.
    The part is for the food industry and the contamination just won’t cut it.
    I spoke to the rep and he insisted that this was “normal” and “unavoidable”.
    I find this a little hard to believe, which brings me here for some sage advice.
    So my first question is whether the company is out to lunch, or that my expectations are too high.
    If the spatter is preventable, how is this done? Adjusting the process? Some kind of sacrificial tube liner? Coatings?
    Many thanks for the help,
    Thomas
    Mar 2016
    94
    Re: 3D laser tube cutting problem
    just a thought
    you could try spraying the inside of the tube with anti-spatter spray the sort they use in mig welding etc for this very reason
    Dave
    Jan 2008
    940
    Fill the tube with sand before cutting
    Apr 2018
    Thanks for the replies.
    I was told by the company that the anti-splatter spray doesn’t work. But I don’t see why it wouldn’t. Perhaps there is just too much spatter.
    Quote Originally Posted by fixtureman1 View Post
    That is an interesting idea. It is a bit tricky logistically though - 6” dia x 8” long pieces cut from a 20’ length full of sand?
    Jan 2008
    940
    You wouldn't need the whole tube filled just enough to absorb the laser beam
  1. gcc c180 laser engraver problem .. laser tube firing a continuous weak beam
    By badrawy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-27-2020, 01:41 AM
  2. RFQ - Laser Tube Cutting
    By JMFabrications in forum RFQ (Request for Quote)
    Last Post: 03-29-2018, 02:18 PM
  3. 60w laser tube co2 laser engraving/cutting machine
    By laserproduct in forum Commercial Laser
    Last Post: 03-27-2018, 07:33 PM
  4. Replies: 0
    Last Post: 12-15-2014, 04:48 PM
  5. BLM tube laser cutting speed
    By dan llewellyn in forum Community Club House
    Last Post: 06-01-2013, 02:59 AM
