585,894 active members*
4,873 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > Closed Loop Belt for z-axis Question
    Question Closed Loop Belt for z-axis Question
    A new member here and I apologize if this post is in the wrong section. If it is please direct me to the correct one.
    I am building a three axis machine out of steel using Arduino and 4 large high torque Nema 23 stepper motors (425). I am running 2 half inch 5 start lead screws for the X-axis, one for the Y, and one 8mm 4 start screw for the z axis. I would like to center the weight over the gantry by mounting the heavy Nema 23 vertically along the back of the gantry trolley and running a closed loop belt to a pulley rotating the 8mm lead screw. The belt would span about 4 inches over the top of the gantry. My idea was to run a 20 tooth 6.35mm bore pulley off of the motor shaft and connect it to the lead screw using a 50 tooth 8mm bore pulley using said closed loop belt. I am estimating that the weight to be lifted (router/z axis components) will be about 13 pounds. Does this sound like a feasible option? This is my first cnc build... i suppose i should mention that...
    Re: Closed Loop Belt for z-axis Question
    Apologize for the picture being rotated. Not sure why it came in that way. Edit: I fixed it
  1. Replies: 0
    Last Post: 03-13-2012, 11:15 PM
  2. New 6-axis Double-Closed-Loop Controller?
    By brccrb in forum News Announcements
    Last Post: 03-05-2009, 04:46 AM
  3. CNC Brain is ready! 6-axis Double Closed Loop Controller
    Last Post: 09-18-2008, 01:42 AM
  4. question on closed loop vs open loop (servo systems)
    By boonie in forum Servo Motors / Drives
    Last Post: 11-09-2007, 07:30 PM
  5. Closed Loop Driver vs. Closed Loop Computer
    By ojibberish in forum Gecko Drives
    Last Post: 06-08-2004, 05:30 PM
