585,712 active members*
4,229 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > can i front/back turn in one Turning project?
    Jul 2018
    14
    If i want to do a front operation, and then physically flip the part to do a 2nd operation on the back, do I do this in one "turning" project? In milling, I would create two coordinate systems; one for from and back, to achieve this. I was not able to get the correct toolpath doing this for turning, because the tool would face the wrong way despite the 2nd coordinate system being oriented properly. Should I create two turning operations instead of two MAC's ? Creating two turning projects mean I have to create two machine configurations and to import all my tools, however. So far I have not been inclined to do that as I have thought it inefficient to do that.
    Jan 2012
    36
    Re: can i front/back turn in one Turning project?
    Hi cryptopsy,
    It was design that turning only allows 1 coordinate system. However, the simple thing to do is have your post set as a MillTurn post and then you will be allowed to add as many coordinate systems as you like.
    Darrin- SolidCAM
  1. IO working Back the Front
    By Burgs in forum CamSoft Products
    Last Post: 01-10-2016, 10:52 PM
  2. Turret front or back?
    By cncsmyhobby in forum Milltronics
    Last Post: 10-31-2012, 02:21 AM
  3. It all seems back to front!
    By pbd1971 in forum Haas Lathes
    Last Post: 09-10-2011, 04:37 PM
  4. My Upside down back to front problem
    By Cosha in forum Mach Software (ArtSoft software)
    Last Post: 03-03-2009, 09:32 PM
  5. TL-1 (program from front or back)
    By WEDDLETON in forum Haas Lathes
    Last Post: 02-24-2008, 04:27 AM
