585,761 active members*
4,101 visitors online*
    Jan 2018
    pocket milling retract problem
    I've come across a problem that I haven't solved.
    I was machining a pocket with an island using multiple step downs.
    The g-code appeared to generate the correct tool path, until near the end of the pass, when the tool moves from one end to the other cutting diagonally across the island without retracting.
    I'm new to Solidcam and CNC but have coding experience, am I missing some setting or is there a bug in the postprocessor?
    Jan 2012
    36
    Re: pocket milling retract problem
    Hi CrazyJane,
    Can you post the offending code? Please include several lines of code before and after the problem area.
    Thank you,
    Darrin - SolidCAM
  1. Problem with pocket dimensions using solidcam 2.5d milling
    By matthew798 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 10-25-2014, 11:21 PM
  2. cnc pocket milling subroutine problem
    By RTC_CNC_STUDENT in forum Fadal
    Last Post: 10-14-2014, 10:58 PM
  3. Pocket Milling Problem - selecting contour
    By Outdoormoto in forum Uncategorised CAM Discussion
    Last Post: 08-18-2013, 05:46 AM
  4. Pocket milling
    By Olavi in forum MadCAM
    Last Post: 04-12-2013, 08:30 PM
  5. Problem with pocket milling...
    By Driftwood in forum GibbsCAM
    Last Post: 09-04-2006, 04:25 AM
