585,992 active members*
5,159 visitors online*
IndustryArena Forum > CAM Software > Alphacam > First Post and Alphacam question
    Jul 2018
    Hello all!
    I been viewing this site for some time now and decided to make a profile finally.
    I work for a high end architectural firm and we are looking to upgrade our cam software. I am relatively new to CAM and CNC operation and have been here for about 8 months and we currently use Router CIM to do all of our programming.
    We are taking a heavy interest in Alphacam and I have acquired a trial of it to give it a test drive.
    So my super complicated question to anyone with experience using Alphacam...
    Can you change the units of the software to inches? Drawing units, tools, machines, everything. I have been messing around for a few hours and can't seem to find a way to set the change the units like you can with any other software.
    Feb 2018
    59
    Re: First Post and Alphacam question
    Scale command 1”= 25.4mm
    or just draw in mm for mm
    i have manuals if you need help,,,,,
    keysoftwareservice.com
    We have a 10 year old version at work. I took a quick look, and don't see a specific setting for inches/mm's. I guess units are whatever you want them to be.
    I see that tools do have an inch/mm setting, and I guess the post processor also can have an effect. We have a custom post that came with our machine, which outputs inch units and metric feedrates.
    Apr 2015
    327
    Quote Originally Posted by mdrum93 View Post
    Hello all!
    "Alphacam does not use imperial (1/2", .25" 1ft., etc) or metric (1mm, 1cm, 1m, etc.) values, rather a unitary value system. Therefore, entering a value of 1 will give you 1 unit, entering .5 will give you 1/2 of a unit. This unit can be read by the user as imperial measurements or metric" - taken from a Alphacam help.
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
  1. AlphaCAM post
    By KLarson in forum Shopsabre
    Last Post: 08-09-2016, 04:32 PM
  2. Alphacam and Xilog3mmi question?
    By m9g in forum Uncategorised CAM Discussion
    Last Post: 07-02-2011, 07:53 AM
  3. AlphaCam Question
    By CNCRob in forum Uncategorised CAM Discussion
    Last Post: 06-21-2006, 11:47 PM
