585,888 active members*
3,972 visitors online*
IndustryArena Forum > MetalWorking Machines > Dyna Mechtronics > DM 2400 8 Wire Stepper Motors
    Mar 2018
    17
    I am curious if anyone has any information on the PMI SynchroStep model# 00S52R6008 8 wire stepper motors that came on the dm2400. I have tried to search for information and have come up empty handed, except for the fact that they were a KollMorgen product.
    I am looking for information as I want to turn the steppers into 4 wire steppers, but I am not sure which of the coils should be paired up.
    Fastest1 had posted that his were Portescap P532 258 0.7 14's. I believe they may be the same motor rebranded as they were also a disc style stepper.
    I have thought about removing the motors, but if I keep the original mounts then I would have to cut shafts down.
    Does anyone have any additional information on this motor or the pinout?
    Apr 2010
    125
    Re: DM 2400 8 Wire Stepper Motors
    Does this look like the same motor?
    https://photos.app.goo.gl/H4Dc8CT3XQcj7ETF6
    It's from my DM4400, it's a Kollmorgen Synchro Step but no model # on it. 200 steps, 140 oz. in.
    I have mine set up as 4 wire (parallel) so if it's the same I can scan that info in for you. I also have a cheat sheet for figuring out what wires are what.
    Dan
    Edit: I meant to say 8 wire parallel, I was assuming that's what you meant, so 4 pairs of 2 wires each.
    Apr 2010
    125
    This is what I used to figure the wires:
    Identify leads on a 8 wire stepper motor – Victor Leung
    Mar 2018
    17
    It isn't the same motor. It is a disc stepper. I believe it was actually made by portescap for Kollmorgen. I called and spoke with Kollmorgen and they didn't keep any information on that motor.
    I used an approach based on that article to figure out the wiring, but I believe these disc steppers behave a little different. I had to start out with 3 coils to get it to really react.
    I have included what I believe is the pinout for the motor. I am jumpering purple-white/brown-white together and gray-white/yellow-white together to wire the motor in series. It appeared to run correctly when I did so.
    This gives me the following wiring going to my 4 wire:
    A+ Purple
    A- Brown
    B+ Gray
    B-Yellow
    I really didn't expect to join white wires together,but that is the only way I could get it to work.
    Mar 2018
    17
    I missed the question I really should have asked. I didn't even think to ask anyone about the typical pinout on this machine.
    I found this excel sheet at https://www.soigeneris.com/document/...nformation.zip. I am sure most on here have seen it.
  1. Wire for stepper motors
    By albolabris in forum CNC Machine Related Electronics
    Last Post: 06-22-2017, 06:32 PM
  2. Can I wire 2 stepper motors together?
    By crandolph in forum Stepper Motors / Drives
    Last Post: 01-05-2012, 02:45 AM
  3. Wire stepper motors to G540
    By microbeast29 in forum Stepper Motors / Drives
    Last Post: 02-08-2010, 11:22 AM
  4. Wire EDM Stepper Motors Not Working
    By sparky212 in forum Stepper Motors / Drives
    Last Post: 01-11-2010, 04:20 PM
  5. Wanted DIY stepper driver circuit for 6 wire stepper motors
    By Colin300 in forum Australia, New Zealand Club House
    Last Post: 09-21-2007, 03:20 AM
