585,875 active members*
4,091 visitors online*
IndustryArena Forum > Community Club House > Facebook Group Discussion > Post procesor for my milling machine
    Oct 2014
    7
    Hi , I built my own 4 axis dental milling machine. It works under Mach 3 so and I need to adapt the 2015 Delcam Dentmill CAM software for my machine kinematics. Is it possible ? All I know is about to create post procesor .
    Apr 2004
    5737
    Re: Post procesor for my milling machine
    If your milling machine only has four axes, the kinematics aren't too complicated. Set up X, Y, and Z as linear Cartesian axes, and A as a rotary axis parallel to X calibrated in degrees. You can do all that in Mach3. If you know how to create the post-processor for that CAM program, it should just work. If not, you should be able to get help from DelCAM, or Autodesk, which acquired them.
    Is that a picture of your "Babin" machine? It looks more like a lathe than a mill...
    Andrew Werby
    Website
    Apr 2020
    Hola, tengo un proyecto similar al que expone en este hilo.... me gustaria saber si ha podido encontrar un postprocesador para esta situacion.... es decir que trabaje desde Dentmill a Mach3.... seria una gran ayuda para mi. Muchas gracias.
  1. ARTCAM POST PROCESOR
    By Miron.Costin in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 09-13-2017, 08:29 AM
  2. Mach2.cnc post procesor for AlphaCAM
    By berikg in forum G-Code Programing
    Last Post: 03-17-2016, 10:10 PM
  3. GibbsCam Post Procesor
    By bbjang in forum GibbsCAM
    Last Post: 12-13-2012, 05:54 PM
  4. Replies: 3
    Last Post: 02-18-2010, 06:16 PM
