Hi Evryone , From South Africa.
Planning to build a Solid mini Desktop CNC lathe , here is just a rough plan\Design currently in progress.
Machine Outside Dimensions H300mm X 450mmL X 320mmD + - 50Kg
MGN9 Linear
Nema 23 Stepper
40mm EN19 Spindle Shaft
ER32 Collet Chuck / 50mm Chinese 3 Jaw Chuck
60mm Turning Diameter X 150mm
Steel Bed
Steel Saddle
Alu Headstock
Tapperd Roller Bearings X3
12mm Ballscrews
500w Brushless Spindle motor 4:1 Ratio = 3000Rpm
any thoughts? Suggestions ect?
Thank You ! Comments Apreciated
