585,982 active members*
4,688 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fagor Automation > FAGOR 800 TG Eror 64 when starting spindle in forward direction
    May 2006
    9
    We have a Fagor 800 tg control on a kingston lathe. Recently started displaying error 64(emergency) when we try to start spindle motor in forward direction. Can't clear error with RESET. It requires a power cycle to clear the error. Seems to be an internal error--it toggles pin 5 of i/o 1 connector from 21 volts to 0 volts. Spindle motor starts and runs fine in reverse direction. If error 64(emergency stop) is generated by the e-stop switch or the brake pedal it can be cleared by the RESET button. The problem only occurs when trying to start spindle in forward direction. Anyone had this problem with a Fagor 800?
    Any schematics for this control available?
    Jeff
    Mar 2008
    169
    Re: FAGOR 800 TG Eror 64 when starting spindle in forward direction
    Mmmm is strange , spindle motor is driven by a VFD?
    May 2006
    9
    Yes the spindle is driven by a VFD. If we put the vfd in local mode it will start in both forward and reverse directions using the buttons on the VFD.
  1. Fagor 8055 Z axis moving in wrong direction?
    By SwampDonkey in forum Fagor Automation
    Last Post: 09-21-2015, 11:09 PM
  2. Spindle Forward/Reverse = High/Low change
    By AdyAstley in forum Machines running Mach Software
    Last Post: 06-07-2007, 03:33 AM
  3. Bridgeport R2E4 Axis limit eror
    By synergymc in forum Bridgeport / Hardinge Mills
    Last Post: 08-20-2005, 02:54 AM
