585,679 active members*
5,852 visitors online*
Thread: 835 ALARM P
Results 1 to 9 of 9
    Mar 2017
    10
    835 ALARM P
    Hello, I have an Okuma M460V-5AX and it won't boot my system. I make the necessary backup, but it does not want to load, if anyone can help I would be grateful
    Re: 835 ALARM P
    Quote Originally Posted by RumenR View Post
    You might need to check the cables and connection, it is communication error.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Mar 2017
    10
    Re: 835 ALARM P
    Quote Originally Posted by cncmakers001 View Post
    I have checked them
    Mar 2009
    1982
    Re: 835 ALARM P
    in my understanding the operating system is booted properly.
    What I would do I would start with optical cables - disconnecting one of them makes no difference, means the one connection is faulty
    Dec 2008
    3108
    Quote Originally Posted by Algirdas View Post
    A "P" level alarm is a critical warning that the starting up of the machine will damage it. It is like a car having a faulty oil pump, check oil pressure, if not correct, shut down.
    It seems there is a comms fault with a device "mcs" that stops the boot-up sequence
    Error manual may indicate what to look for.
    I'm guessing here ... "mcs" might mean "master control system"
    It could mean a HDD problem, lost parameters, card fault, or cable.
    What OS is the machine ? (OSP, P,etc)
    Mar 2017
    10
    Re: 835 ALARM P
    Quote Originally Posted by Superman View Post
    OSP
    Mar 2009
    1982
    Re: 835 ALARM P
    what OSP ?
    OSP 10
    OSP 100
    OSP 200
    OSP 300
    OSP 500
    OSP 5000
    OSP 700
    OSP 7000
    higlight please.
    Mar 2017
    10
    Re: 835 ALARM P
    what OSP ?
    OSP 10
    OSP 100
    OSP 200
    OSP 300
    OSP 500
    OSP 5000
    OSP 700
    OSP 7000
    higlight please.
    Sorry, OSP-P300MA-H
    Re: 835 ALARM P
    MCS= Motion Control System (motor, encoder, drive, etc)
    0835 MCS Communication
    An error occurred during shake-hand communication with MCS.
    [Index]
    Axis name or none
    [Character-string]
    Shake-hand communication error number (2 digits) and [command name]-[channel number]-net address (controller
    number)
    [Code]
    Error data when an error occurred (Zero suppression is effective for upper figures in 8 digits) (Details differ according to the
    shake-hand communication error number.)
    [Probable Faulty Locations]
    1) Faulty software
    [Measures to Take]
    1) Change the software.
    Do you have original DVD with software? with matching options? Go to windows only mode and try to re install it?
  1. Hyundai Kia SKT 100 turret amp alarm AL 62 (Alarm 2062)
    By roboticist in forum Hyundai Kia
    Last Post: 02-16-2022, 06:01 AM
  2. Alarm 20 NMI emergency stop and alarm 204 spindle controller malfunction
    By bdrotaru in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-25-2019, 04:36 PM
  3. Replies: 1
    Last Post: 04-12-2014, 11:15 AM
  4. Replies: 6
    Last Post: 03-13-2013, 03:32 PM
  5. Replies: 4
    Last Post: 06-12-2009, 09:15 PM
