585,962 active members*
3,978 visitors online*
IndustryArena Forum > MetalWorking > Casting Metals > Casting and rolling of aluminum sheet plate
    Aug 2018
    Casting and rolling is a new process of directly casting and rolling metal melt into semi-finished or finished products. The remarkable feature of this process is that the crystallizer is two rotating casting rolls with a water-cooling system. The melt completes the two processes of solidification and hot rolling between the rolls, and is completed in a short time (2~3s).
    Casting and rolling is a new technology developed in the 1970s. Its advantage is that the molten metal liquid directly produces the metal material by directly crystallizing, casting and rolling the rotating crystallizer.
    We are well known aluminum sheet plate manufacturers and suppliers we expert in 3003 5052 6061 7075 aluminium alloy sheet plate coil and so on.
    Website : http://aluminumsheetplate.com
    Email : [email protected]
    Hi
    Pls.
    How to cast 7075 alloy?
    Re: Casting and rolling of aluminum sheet plate
    Pls.
