586,024 active members*
4,064 visitors online*
IndustryArena Forum > Manufacturing Processes > Grinding > The main Problems for Resin Bond Grinding wheel in using
    Aug 2018
    Some times when we use the Resin Bond Grinding wheel, we would meet some problems. Sometimes, we could solve it, while sometimes we do not know what happened. Today we will talk about the main Problems of Resin Bond Grinding wheel.
    1.The Using life.
    Some customers think the using life of Resin Bond Grinding wheel is shorter than other Grinding wheel. Yes, it is!
    The advantage of Resin Bond Grinding wheel is: High Grinding efficiency because resin bond grinding wheel has best self sharpness. It leads to the Highest grinding efficiency while the Using life is shorter than other grinding wheel.
    If you want to solve this problem, firstly let the factory know, and they will adjust the Productive Formula to increase the using life. And then keep the same smoothness on the work pieces, choose the Finer Grit. No. will good choice too.
    2.The Abrasive Layer Dropped.
    There are Two main reasons. One is Production Processes has Problem, the strength of abrasive layer is not good; and another reason is: when use the grinding wheel, the Pressure on the Grinding wheel is too much. Or the Grinding feed per time is too much.
    If the Quality Problem, contact with factory to solve it; if the using problem, adjust the using method and grinding feed.
    3.Smoothness on the work piece is not good.
    Choose the Suitable Grit. No. is also very important. Suitable Grit. No. could reach to the smoothness which you need. Besides, if the Grinding allowance is too much, firstly should choose the Coarse Grit. No. to grind, and then choose the finer Grit. No. to grind, at last choose the finest Grit. No. to polish.
    4.Need to dress Resin Bond Grinding wheel frequently.
    Because Resin Bond Grinding wheel has best self sharpness, so if want to keep the shape after grinding, yes, the resin bond grinding wheel need to dress again and again. It will caused by its’ Characteristic. While if you want to less the dress time, you could discuss with factory to increase the concentration of Diamond / CBN, and increase the hardness of Resin Bond Grinding wheel. It will less the dress time, while it will not solve it completely.
    Different Bond Grinding wheels has Different Characteristic. According to your detailed requirements to choose the suitable Grinding wheel, it will avoid much trouble. The best way is: supply enough more using information to the factory of Grinding wheels, they will recommend the suitable Grinding wheel for you!More Details Would Be seen our website: https://www.beherohome.com/products/...ing-Wheel.html
    Nov 2019
    Quote Originally Posted by YingLong View Post
    1.The Using life.
    Damm even I am having a similar kind of issue, I have searched all over the
    internet and even have posted on number of threads on different forum, no
    solution seems to work. I am really frustrated, can anyone of you here help
    me resolve this issue, I am very much tired now.
