Hi!
can any one please help me solve this problem...
VBA Macro Error
C:\AlphaCAM\Licomdir\VBMacros\StartUp\XilogPlusPos t\OuputNC_XilogPost.arb
I am trying to run Alphacam 2018 R2
Hi!
VBA Macro Error
By this description nobody can solve this problem. Upload your VBA macro or make a screen your error.
Alphacam post and VBA macros, Autodesk HSM post.
www.cadcam-softcz.cz
this error means you are not authorized to use the post,,typically the lincense to the post is linked to your dongle,,,if you need more help email me,,
keysoftwareservice.com
PS: if you puchased your post with alphacam 2017---it will not work with any other versions,,unless you hire a post writer or vba specialist,,this looks like this thing belongs to alphacam 7
You have problem with a a 64bit implementation. Post is written for 32 bit Alphacam version.
Function inside of code must be declare as a PTRSFE.
Like this.
Private Declare PtrSafe Function WritePrivateProfileString Lib "kernel32" Alias _
"WritePrivateProfileStringA" (ByVal lpApplicationname As String, _
ByVal lpKeyName As Any, ByVal lsString As Any, ByVal lplFilename As String) As Long
Marek
