585,902 active members*
4,123 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Power 500W Spindle from 1/5kW VFD
    Oct 2007
    25
    I have a 500W Chinese spindle. No information or nameplate of course. The only specs I have:
    • Working voltage: 48 V DC
    • Power: 500 W
    • Speed: 12000 r/min
    I would assume from this that the max current is 10.4A.
    Can I control this with a 1.5kW VFD, e.g. Huanyang? What is confusing me is the DC "working voltage".
    Here is the spindle: https://www.ebay.co.uk/itm/ER11-500W...K/232697475814
    Thanks!
    Jan 2007
    626
    Re: Power 500W Spindle from 1/5kW VFD
    You have a ESC that converts DC into 3 phase AC to drive the motor, they 8call* it a 'Brushlesss DC motor' but its actually a 3 phase motor.
    R/C modle planes use the same layout.
    I am not sure it will work or not ...it depends on a few things.
    You need to know all the Input specs for the motor and determine if the VFD paramters can be set to match. If not you won't be able to protect your motor from damge if something is wrong.
    Besides motor voltage and current, an important one is the max frequency of the motor.One is not usually this info set these setups.
    If you get it wrong you can damge the motor and/or the VFD.
    If you had an Oscilliscope you could take some measurements...see what frequency the ESC goes up to?
    It may be dangerous ground...not 100% sure.
    If you don't have the experience or knowledge, I would probably not proceed.
    Why do you want to do this?
    Do you want to control the Spindle from Mach 3?
    15362
    Quote Originally Posted by ajayre View Post
    • Power: 500 W
    Thanks!
    Quite easy to answer your question, No you can't run this motor with a VFD
    That is a regular 48v DC motor, it has its own special BLDC control showing in the package
    Mactec54
  1. Upgrading my 3040 with a 500W spindle (replacing the 300W one)
    By MustangviennA in forum Chinese Machines
    Last Post: 01-31-2019, 11:53 PM
  2. MAHO 500W
    By Elitsa in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-25-2017, 02:40 PM
  3. Replies: 39
    Last Post: 01-09-2017, 06:26 AM
  4. How do I power spindle F1 that is missing its power supply
    By Ayyub2007 in forum EMCO CNC Machines
    Last Post: 09-28-2016, 03:17 PM
