585,967 active members*
4,421 visitors online*
    Apr 2018
    5
    making usb work
    I haave cnc10 on v2.36 this was upgraded on a previous motherboard that previously ran dos but now linux.
    I have the USB plugged into the first row of pins closest to the control panel face.
    How do I access the usb drive from the interface. How do i figure out which directory it should be under etc?
    yes I have formatted the USB flash drive in fat system and it is labeled default
    Also i still get a floppy drive error even though i do not have a floppy
    any help would be a god send
    Feb 2008
    280
    Re: making usb work
    Not all brands and models of USB drive work with that version of Linux.
    See if you can lay hands on a SanDisk Cruzer, preferably an older one with 4GB or less capacity.
    It should show up in the F2/Load and F7/Utility -> F5/File Ops menus as drive a:, b:, e:, or something higher, depending on whether the system is configured to expect a floppy disk drive; whether it is the first USB drive plugged in; and whether you have mapped any network drives.
    After you plug in a USB drive, it usually takes the system five or ten seconds to detect and mount it. If you already opened a file menu (e.g. F2/Load) then you will need to press F5/Refresh before you will see the USB drive in the list.
    If you are comfortable using Linux shell commands in a command prompt window, you can also view the contents of the /cncroot/ directory to see what devices are mounted.
    Mar 2016
    42
    Re: making usb work
    If you don't have a floppy drive installed, you need to make sure that you turn that off in the BIOS menu. If you don't, you will always get that Floppy Drive Error message when you power the system on as the BIOS is telling the motherboard that it has a floppy drive installed but the motherboard can't communicate with it which is why it's displaying that error message. You could also have an issue in which the directory that you are using for the floppy has been accidentally created. Press ALT+F6 to bring up the Linux command window. Type ls /cncroot and press ENTER. What do you see? Plug the USB stick into the control and wait 10 seconds. Press the up arrow once which will automatically fill in the previous line you typed and press ENTER. What do you see?
  1. Cnc router sign making,furniture work
    By omnisales6 in forum European Club House
    Last Post: 07-12-2016, 02:37 AM
  2. Making a mirror image part? Will this work?
    By DrewSmith007 in forum Mach Software (ArtSoft software)
    Last Post: 11-11-2011, 06:20 AM
  3. Making Stepper Motors Work Reliably
    By SCzEngrgGroup in forum Benchtop Machines
    Last Post: 09-14-2009, 09:11 AM
  4. ATX (New) PS - Making it Work - HELP
    By Santa Fe Al in forum CNC Machine Related Electronics
    Last Post: 04-19-2009, 05:07 AM
