585,951 active members*
4,060 visitors online*
IndustryArena Forum > Manufacturing Processes > Grinding > Electroplated diamond Mounting Point
Results 1 to 1 of 1
    Aug 2018
    Electroplated diamond Mounting Point is one of the wheel in the electroplated Grinding wheel, is to use certain bonding to bond the abrasive, generally installed in the grinder, grinding machine, polishing machine, or special installation tools, widely used in optical lenses, prism, watch glass, sapphire glass.
    Through the processing of various parts, in order to achieve grinding, grinding, polishing effect; According to the use of use, mainly divided into the following mounting point:
    1, Grinding categories: mainly installed in the grinder, the work-piece for internal grinding, cylindrical grinding and other grinding, grinding, processing can be divided into coarse grinding and fine grinding.
    2, Grinding categories: Generally used for grinding the work-piece burr, or the work-piece surface precision is not high processing. Use grinding machine, electric, pneumatic and other tools to achieve high-speed grinding effect.
    3, Polishing categories: Specifically for the surface finish (roughness) demanding processing and use, is the need for separate processing steps.
    Electroplated diamond Mounting Point is with the same advantages as electroplated grinding wheel : Due to the high hardness of diamond itself. It has man-made and natural points, of which the natural hardness is higher, but it is scarce and expensive. As a result, the most widely used synthetic diamond abrasive products in the market today are. Therefore, the use of diamond grinding is also more extensive, this variety of diamond grinding mounting point and specifications according to national standards there are many types, particularly in the performance of size and shape. These are based on the use of diamond mounting point to determine, such as grinding the hole with a grinding point is very prominent, but it is also a good helper of ordinary mounting point, especially when used in hard-to-wear materials is particularly evident.
    As the diamond Mounting Point as electroplated grinding wheel is based on diamond abrasive, and then by the resin, metal, ceramic and other bonding. Under this condition, the use of diamond mounting point is also more special, grinding holes and other grinding wheel where can not be indispensable, it is mainly used for grinding, polishing, grinding purposes. At the same time based on the above characteristics of diamonds, according to the material can be divided into high and hard grinding alloy, non-metallic materials.
    In this regard, the use of diamond mounting point compared with ordinary diamond grinding wheel, it is high hardness, high compressive strength, good wear resistance, diamond mounting point in the grinding process, as grinding hard and brittle materials and Carbide ideal diamond tool, use it to grind the work-piece not only high efficiency, high precision, and good roughness, less wheel consumption, long service life, but also improve working conditions.
    Therefore, the use of this diamond mounting point becomes more and more obvious. It is widely used in low iron content metal and nonmetal hard and brittle materials such as cemented carbide, agate gem, high aluminum porcelain, optics Glass, semiconductor materials, stone and so on. In the grinding industry, due to the different materials being processed, the abrasive bonding properties vary. Electroplating head is one of them, it is made of diamond or CBN abrasive, especially for hard grinding materials, high precision materials, grinding of super-hard materials can play an important role.
    If you want to know more information about electroplated grinding wheel, contact with us:https://www.beherohome.com/products/...ing-Wheel.html
