585,880 active members*
7,124 visitors online*
Results 1 to 11 of 11
    Dec 2007
    15
    G-code "bigger" than machine area
    I have some g-code files written for bigger machine.
    I want to subtract the same number from each X coordinate in the file, so the code will fit into my machine.
    Doing this manually is a enormous job.
    Does someone knew how to do this automatically?
    Here is an example in attachment.
    Any help will be appreciated.
    mrpeja
    Re: G-code "bigger" than machine area
    Some controls allow you to scale the g-code up or down in size.
    Nov 2012
    1267
    Do you want to scale the part or shift it? If you want to shift it, just change the origin on the machine itself and leave the G-code file as is.
    Dec 2007
    15
    Hi, CitizenOfDreams,
    Thanks for fast reply.
    I want to shift the part.
    Because machine's mechanical area is so small that I can't change the origin on the machine itself, it is still near to mechanical limit at the beginning and
    biggest X axis coordinate feeds into another mechanical limit switch.
    There is some margin incorporated in code during generating G-code file(about 0.3 inch) and I want to substract this amount from each X number.
    Is this possible (but not manually)?
    mrpeja
    Nov 2012
    1267
    Subtracting a fixed number from all the X coordinates would have exactly the same effect as shifting the machine origin. How much X travel does your machine have?
    May 2005
    1662
    If you need to split or scale gcode G-Code Ripper can do this. Don't worry his software is safe (no virus) and reliable
    Link below:
    G-Code Ripper
    Anyone who says "It only goes together one way" has no imagination.
    Dec 2007
    15
    My machine has travel up to 19 inch and in another file (not this I have sent) there is coordinates up to 19,5 inch.
    I have G-code ripper already downloaded, but didn't realize how to shift origin, yet.
    Shift or split?
    Maybe some help?
    mrpeja
    Nov 2012
    1267
    I still do not understand why you are insisting on shifting the coordinates in the g-code and not on the machine. If your file goes like this:
    G0 X7000.0
    G0 X7005.0
    you can still run this file as is on a 5-inch machine by setting the machine's origin to X=7000.
    Jun 2015
    4154
    hi mrpeja, i hope i got it rigth : pls check attached, about shifting X coords of your file
    you may split your code and shift each fragment, or leave the fragments as they are & shift the origin of the program ( like put the origin out of the machining area )
    also, there are other solutions, like :
    ... creating the program in the right way from the start, so to avoid later editing time; a cam that can restrain a toolpath inside a perimeter should do the job
    ... replace X15.456 with X=common_variable+15.456, and initialize the common variable with the desired translation value; this is faster then editing the entire code content
    kindly
    Code:
    M3
    N4571 T5 M06 S0
    N4573 G81 X-14.872 Y0.591 Z-0.2800 R0.0500 F12.00
    N4575 X-14.469
    N4577 X-19.518
    N4579 X-19.921
    N4581 X-24.567
    N4583 X-24.97
    N4585 X-29.616
    N4587 X-14.872 Y7.795
    N4589 X-14.469
    N4591 Y-21.801
    N4593 X-14.872
    N4595 X-19.518
    N4597 Y-22.205
    N4599 X-19.921
    N4601 Y-21.801
    N4603 X-24.567
    N4605 Y-22.205
    N4607 X-24.97
    N4609 Y-21.801
    N4611 X-29.616
    N4613 Y-22.205
    N4615 Y-14.596
    N4617 X-24.97
    N4619 X-24.567
    N4621 X-19.921
    N4623 X-19.518
    N4625 X-14.872
    N4627 X-14.469
    N4629 G00 X-14.469 Y15.404 Z0.0000
    M02
    M30
    Attached Files Attached Files
    Jun 2015
    4154
    hello again, maybe code translation will work for you :
    Code:
      ( this is your code, edited )
        #500 = - 30 ( translation value )
        M03
        T5 M06 S?
        G81 X=#500+15.1280 Y00.5910 Z-0.2800 R0.0500 F12.00
            X=#500+15.5310
            X=#500+10.4820
            X=#500+10.0790
            X=#500+05.4330
            X=#500+05.0300
            X=#500+00.3840
            X=#500+15.1280 Y07.7950
            X=#500+15.5310
                           Y08.1990
            X=#500+15.1280
            X=#500+10.4820
                           Y07.7950
            X=#500+10.0790
                           Y08.1990
            X=#500+05.4330
                           Y07.7950
            X=#500+05.0300
                           Y08.1990
            X=#500+00.3840
                           Y07.7950
                           Y15.4040
            X=#500+05.0300
            X=#500+05.4330
            X=#500+10.0790
            X=#500+10.4820
            X=#500+15.1280
            X=#500+15.5310
        G00 X=#500+15.5310 Y15.4040 Z0.0000
      ( M02 )
    M30
    or a temp work coordinate shift ?
    Quote Originally Posted by mrpeja View Post
    ... but didn't realize how to shift origin
    pls share machine and control : if you are lucky, someone will give you the right codes / kindly
    Dec 2007
    15
    Hi, deadlykitten,
    Thanks for the reply. I think this will be the solution if Mach1 (Weeeery oooold!) can understand code translation. I must look in manual for Mach1.
    If someone already knew, please let me knew me to.
    By the way, my machine is homemade.
    mrpeja
  1. Profile Rail Wood Frame Router, 25" x 37" x 6" working area
    By jpvonoy in forum CNC Wood Router Project Log
    Last Post: 03-01-2019, 03:47 AM
  2. Replies: 5
    Last Post: 12-08-2014, 05:00 AM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. Post adds "A0." code and machine stops
    By lookingforhelp1 in forum Fanuc
    Last Post: 08-29-2008, 06:58 PM
  5. Post adds "A0." code and machine stops
    By lookingforhelp1 in forum Post Processors for MC
    Last Post: 08-29-2008, 06:14 AM
