S&M issue, IT IS NOT A KINKY QUESTION!!!
Hello,
Weeks ago I wrote you requesting parameters for a bridgeport vmc 3020 with a fanuc control 21i. As nobody had a similar machine I proceeded with a backup of a vmc2216 with the same control. After weeks the machine is moving, everything seems to be ok except for the fact that i have a S and M conflict. If I have an S command and a M command together in the same program or same block, the spindle won´t work, and no alarm is displayed. But the spindle does work, if I define the speed or the direction of the spindle in MDI and then I only write the other command in the program it does work but not in the same program.
I hope you can help me with this issue
jolulank
www.doctornumerico.com
cnc physicians
