585,728 active members*
4,120 visitors online*
Results 1 to 7 of 7
    Aug 2004
    218
    Mitsubishi spindle alarm 5022
    Hi Guys
    I bought a hitachi seiki HT20II and it has this Mitsubishi spindle alarm 5022 on the CRT and a #33 on the amp itself,can anyone tell me what this means
    Any help at all would be great.
    Mike Roy in Canada
    Smile Spindle alarm
    I know squat about Mistu alarm codes, but moving a machine can
    cause problems common to all:
    Check the quality of your 3-ph power to the machine.
    A difference in voltage or amperage available to the machine
    (compared to where the machine was installed before) has caused
    trouble for many.
    Is there a voltage selector (230/240/280/300 etc...)?
    It must match your available power.
    Do you run it off of a phase Converter?
    Jan 2006
    61
    Quote Originally Posted by mroy0404 View Post
    Hi Guys
    Mike Roy in Canada
    If this is a Fanuc spindle amp, alarm 33 usually means an open regen resistor on the mother board. There are two of these 100 ohm high watt resistors.
    You can sometimes get by soldering a new one onto the board. Otherwise
    you must replace the amp. What kind of machine, a hobber, drill, mill or what?
    765
    Mike,
    What's the model number on the front of the spindle drive?
    Scott
    Aug 2004
    218
    Thanks for all the replies, it seems like i have hope here.
    MetLHead
    The amp is a FREQROL Mitsubishi AC spindle controller modal FR-SF it also says type FR-SF-2-11K-PC
    BN404U 482
    Serial # W43825002
    on the serial tag
    Spark-el
    This is a CNC lathe 1990 2 axis machine
    765
    Mike,
    According to the Mitsubishi manual, alarm code 33 is an overvoltage alarm.
    http://www.meau.com/Files/BNP-A0801-72.PDF
    This is a link to the troubleshooting manual, should be of some help.
    Scott
    Apr 2007
    5
    fr-sf-spindle
    it is likely that either your sf-pw p.s. is going out or you have some shorted modules in the bse unit.if you still need help give me a fax number and i can fax you some detailed info on a quick easy way to check the base unit with an ohm meter.good luck
  1. Mitsubishi spindle problem
    By wcopley in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-03-2013, 08:58 PM
  2. Mitsubishi IPM overheat alarm
    By rjboz in forum Daewoo/Doosan
    Last Post: 12-22-2006, 09:46 AM
  3. mitsubishi spindle servo motor
    By intermax in forum Stepper Motors / Drives
    Last Post: 11-08-2006, 02:29 PM
  4. mitsubishi spindle servo drive
    By intermax in forum Servo Motors / Drives
    Last Post: 11-03-2006, 04:15 PM
  5. Mitsubishi Sinker Spindle Rotation
    By squarewave in forum Waterjet General Topics
    Last Post: 06-02-2006, 12:33 AM
