585,719 active members*
4,054 visitors online*
Page 3 of 3 123
Results 41 to 44 of 44
  1. #41
    Mar 2012
    143
    Re: Emco F3 mill conversion
    Can a Bosch bi metal holesaw cut through cast iron or do I need a carbide tipped holesaw ?
  2. #42
    Dec 2013
    5717
    Quote Originally Posted by fastbike View Post
    The bi metal holesaw should be fine unless you hit a very hard spot in the casting. If it is a quality casting, then I would expect no problem.
    Jim Dawson
    Sandy, Oregon, USA
  3. #43
    Mar 2012
    143
    Thanks Jim, I'll probably be giving this a go in the next week or so. I thought I should ask the question in case I had to order in a carbide holesaw, so nice to know I can try with an ordinary bi metal.
    Fingers crossed that Emco castings are quality.
    David
  4. #44
    Mar 2012
    143
    I'll need to make a guide piece so I can centre the pilot drill in the existing hole in the casting. That's been put on hold while I get the control enclosure/wiring progressed.
Page 3 of 3 123
  1. EMCO FB-2 CNC Conversion- HELP
    By diabolik in forum EMCO Mills
    Last Post: 07-26-2018, 04:07 PM
  2. EMCO F1 CNC mill CONVERSION - beginner!
    By MrDreee in forum EMCO Mills
    Last Post: 07-07-2017, 11:03 AM
  3. EMCO PC 50 Mill Conversion
    By blizbiggy in forum EMCO Mills
    Last Post: 06-11-2012, 06:47 AM
  4. Emco PC 5 Conversion
    By Nigel_B in forum Australia, New Zealand Club House
    Last Post: 10-23-2006, 10:38 AM
  5. Emco f1 mill conversion help
    By no1uno in forum Benchtop Machines
    Last Post: 11-10-2004, 09:58 PM
